89 YJ jp 18 project
Re: 89 YJ jp 18 project
Post by RustyRodder » August 22nd, 2017, 10:24 am
You are a brave man!!!
Dritzz
Post by Dritzz » August 23rd, 2017, 10:52 pm
picked it up for $150 .and it runs and drives so i figure after i take the bar out . i could use the rest for a field car . or sell the rest and get my money back
mr_cox
Post by mr_cox » August 24th, 2017, 4:51 am
Wow that one is en really rough cosmetical shape.
The bumperettes at the rear look in good shape. Are you willing to sell one and ship it with USPS to The Netherlands?
And the center cap of the steering wheel (if all white tabs on the inside are in good shape).
Thanks!
Nice build btw :D
Chase65
Post by Chase65 » August 24th, 2017, 11:45 am
Make the parts Jeep into a wrecked and weathered #10!
1993 YJ Sahara
1994 Explorer Limited
2004 Mercedes ML350
Dritzz
Post by Dritzz » August 25th, 2017, 7:37 pm
so i have broken 5 or so t45 bits removing the roll bar from the parts jeep ... so off the the store in the morning to get some more . then off with the sport bar. i will try to get some good photos . lets hope everything goes well .i did end up grinding off the 8 bolts that hold the bar to the floor just behind the front seats . lets hope jp18 is not as bad.. :)
KytorIndustries
Post by KytorIndustries » August 26th, 2017, 7:04 am
I don't even bother trying with some of them, just weld a grade 8 bolt to the T45 head and take it off with an impact.
Kytor Industries
kytor.com
Post by RustyRodder » August 26th, 2017, 3:25 pm
Or torch them. Not going to be reused anyway!
Dritzz
Post by Dritzz » August 30th, 2017, 9:42 pm
so the rollbar in my jeep came out great . sprayed the bolts a week ago with pb blaster and every one turned right out. i figured the 95 bar would be a direct replacement to the 89 sport bar, however the 2 bottom bolts on each side needed to be drilled out a little to fit. but everything turned out ok in the end .
Dritzz
Post by Dritzz » September 4th, 2017, 3:55 pm
so i got some more work done on the roll bar . test fit everything and so far it looks good.decided to weld a few brackets on the right side so i can mount the cb antenna in a rubber grommet .anyway got it into primer and with any luck i will have it on tomorrow.
I think im going to just use stainless washers and bolts to reinstall everything.
KytorIndustries
Post by KytorIndustries » September 5th, 2017, 8:08 am
That's what I did. The factory torx hardware is garbage.
Anti-Seize + stainless washer and bolts. Never have to worry about a stuck bolt again.
Kytor Industries
kytor.com
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
