Bob's 88 wrangler
redninja223
Bob's 88 wrangler
Post by redninja223 » June 20th, 2010, 10:57 pm
alright so i got my jeep a few weeks ago,i payed $1700 for it. its an 88 with about 177k. its runs ok but is very loud because the exhaust is broken just before the catalytic converter. i dont plan on getting it painted like a jp jeep for a year or so because i have other things to work on first. the engine is the 4.2l with 5 speed manual transmission. i plan on having the trans rebuilt sooner or later.
Uploaded with ImageShack.us
doors off at work, the big guy is my boss
i had the windshield down to replace the cowl seal.
today i sanded the rust off the floor panel under and around the drivers seat then sprayed primer on it
before:
after:
now:
AJ Quick
Re: Bob's 88 wrangler
Post by AJ Quick » June 21st, 2010, 1:39 am
I'm amazed by the lack of rust!
A great looking Jeep to start out with.
Don't forget to seal that primer with a paint or liner.
redninja223
Post by redninja223 » June 21st, 2010, 2:46 am
i think im going to primer the rest of the tub then use the blue paint i got with it to match the blue. i really want to herculine it sometime though
there is also some pretty bad rust on the tail gate, im getting that tomorrow. hopefully its easier then the floor was
cklinejr
Post by cklinejr » June 22nd, 2010, 1:10 pm
AJ Quick wrote:Don't forget to seal that primer with a paint or liner.
Its true, I just learned last week that primer is porous and will soak up water.
I always thought that if you had a coat of primer on something it would be fine, but nope.
Post by Railtech » June 22nd, 2010, 4:14 pm
I have had some really good results with POR15 in these moderate to severe surface rust applications. I have a local source in Atlanta, but it can be found online. Basically you brush it on like paint let it dry and harden then you can skim coat with bondo or whatever filler and it won't bubble back up after a year. I have rebuilt several WWII/Korea/Vietnam era rustbucket 1/4 ton trailers and that works great. Normal primer doesn't bond with the rust like POR15 does. A quart goes a long way, it applies very thin.
On frame/underbody applications I don't even topcoat the POR15. The semigloss looks really good.
Nice Jeep BTW: that pretty clean for an 88. Another consideration if you want to redo the tranny is get a AX15 from a later model YJ/TJ/XJ and perform a swap. Its pretty straightforward and requires little retrofitting. Not to mention almost any Jeep with a 6cyl had an AX15, its a little stronger with a 1 piece case and external slave cyl for maintenance.
redninja223
Post by redninja223 » June 22nd, 2010, 9:33 pm
yesterday i sanded the tailgate down, got all the rust off and primerd it. then i took out all of the interior because im going to sand down the rest of the tub and primer it. today i took off the side steps only to find more rust, one spot lead to a decent size hole. so tomorrow im going to bondo that hole paint the tail gate and sand down the tub, possibly primer the rest of the tub. i wanted to have the interior back in by the end of today but that didnt happen =/
redninja223
Post by redninja223 » June 24th, 2010, 10:45 pm
i sanded all the rust off the tail gate, primed then painted it
before:
after:
i also did finish sanding/primering/painting the floors, here are some pictures
AJ Quick
Post by AJ Quick » June 24th, 2010, 10:56 pm
Looks great!
cklinejr
Post by cklinejr » June 24th, 2010, 10:56 pm
Lookin good.
redninja223
Post by redninja223 » June 24th, 2010, 11:11 pm
thanks=] i also sanded off the ugly rotting stickers above the side steps and re painted it there
Users browsing this forum: Bing [Bot] and 63 guests
