Vehicle Maintenance Log
Re: Vehicle Maintenance Log
You need explorer parts? I put my eyes on one in the LKQ tulsa lot not to long ago. I remember saying "ooh lookie there, a explorer with the right wheels and grill"
Did you use a regular log book and just put decals on it or is that a whole printed front cover?
- DrewSmith007
It's one of these: http://www.officedepot.com/a/products/3 ... s-_-323629
I printed the front and back cover on cardstock. Then, for the front, I figured where the left edge needed to be for the graphic to be centered and cut it there. Then, I spra glued the back of the paper and attached it to the cover. The black spine on mine is the same as what was on the original notebook. Then I flipped it over, cut about 1/8" from the edge, then cut the corners at 45 degrees and folded and glued that edge around the original cover. Same thing for the backside.
As far as parts, yeah I need them, mostly the rear glass for some tint removal experiments I'm wanting to try. I need an XLT badge too. I'll check that place out JT, thanks.
