Pennsylvania Jeep #12
- Jack_Fauth
Re: Pennsylvannia Jeep #12
Finally got around to getting some work done on #12
Lightbar showed up Friday, an original Mopar one, cut it down by a little over a 1 1/2" and the height looks pretty good to me.
Also my plate showed up, all the ones related to a JP12 jeep were all taken
I chose this one... Also got to work on the body Saturday and Sunday. This jeep had oversized tires that ruined the wheel wells so i got a set of perfect ones.
here is where she sits after owning it 6 weeks
|--L@/--[]lllll[]-
|--L@/--[]lllll[]-
- mydigitalvoid
Coming along nicely!
- Jack_Fauth
another update and then i think I am done till after winter...
Got my lightbar sanded and painted and found another light , just need 2 more... next i remounted it
also found a Ramsey winch on e-bay with the old sticker...
|--L@/--[]lllll[]-
|--L@/--[]lllll[]-
- Jack_Fauth
Still have to decide if i want a working winch or just a prop...
Speaking of props I also got this finished up to take to car shows to sit beside my #12
Last edited by Jack_Fauth on September 26th, 2011, 12:59 pm, edited 2 times in total.
|--L@/--[]lllll[]-
|--L@/--[]lllll[]-
- Jack_Fauth
all parts are now aquired less 2 jabsco lights. Paint and decals and my Jeep will be ready to show off.
Not sure if i want to paint before the spring or not, if we have a bad winter the paint might get messed up
here is how she sits as of today
|--L@/--[]lllll[]-
|--L@/--[]lllll[]-
- Maverick20
what winch plate did you use? i didnt know you could still use the tow hooks with a winch plate?
1995 YJ Sahara
- mydigitalvoid
Looks awesome Jack, getting closer!
- Jack_Fauth
it came with the winch i got from e-bayMaverick20 wrote:what winch plate did you use? i didnt know you could still use the tow hooks with a winch plate?
The lister said it was a 36" Promark Universal Mounting Channel
It worked out well, it bolts right to the tow hook spots and the driver side has the channel cut out to put your old hook back on.I even used the factory tow hook bolts to mount it. The passenger side is not cut out and needs shorter bolts which i picked up at a hardware store. No drilling required to mount the plate.
It came with a roller fairlead which i removed and now just need to replace it with the screen correct flat one.
|--L@/--[]lllll[]-
|--L@/--[]lllll[]-
- Maverick20
That looks good, can't wait to see it finished.
