JP 13 TJ - We Will Rebuild
Since its original purchase, the Jeep has received many functional upgrades; 8.8 axle in the back, HP dana 30 in the front, Undercover Fab Ultra-High Clearance Skid, 4.88 gears, rear OX locker, front locker, etc., etc., but never anything cosmetic. I'd been lurking on this forum for awhile, as it's always been a dream, so I had just enough info to be dangerous. Sand Beige Metallic and Ford Performance Red were my chosen colors, and EdynB so graciously posted an image with all the line measurements/angles for a TJ in the paint section, along with vendors to purchase the logos and stencils from. I had all the info I needed, and most importantly, a best buddy who happens to be a manager at an auto body shop. You've read enough text. Feast your eyes: First thing we did was tear it down and Herculine the interior, because why not? Here it is torn down prior to sanding. We fit the CCFabs hoodline fenders, then removed them for undercoating. Also put some undercoating on the inner fenders as well, after the plastic was removed. Then we sanded and painted the roll bars. We just had to get a taste of the paint prior to finishing up that particular weekend. Then came a whirlwind of sanding, fitting parts, then finally PAINT. Prep work takes a long time, and it feels like you're getting no where, but once that first coat of paint licks that metal, it's all worth it. Once the beige dried, we made all the measurements using a protractor and painter's tape. We also laid all the stencils. We chose to let the bare metal show through on the fenders and the hood. We took a few artistic liberties because, after all, it's a TJ, not a YJ. We installed a hood louver to let the engine compartment breathe while the AC is running at low speed crawl. It's a cushy, coil spring TJ... come on! We also wanted to show off that aluminum. Might have someone pinstripe the outline in the same red later on... We also installed some GenRight Tall Tub Guard Panels on each side. Also in aluminum, these will hopefully minimize damage if similar events occur. They're pretty thick, and grinding out a slot for the lower door hinges was rough. Probably the most gratifying part of this entire project was putting those logos on the doors. Those half doors with the JP logo make the whole thing. We also installed some Rugged Ridge Light Bar Mounts, and a $60 52" light bar from Amazon that works pretty darn good. Pictured there is JD, the master bodywork/painter. You can hardly tell any damage occurred even if you know where to look! Spared no expense. And here is the finished product, although we all know that there is no such thing as a "finished" Jeep: I think it's safe to say that this is the only JP Jeep in Corcoran, CA. I haven't seen one in Fresno either, where all the work was done at JD's Autobody.
-Herculined the entire bed of the Jeep.
-Removed all body damage
-Installed CCFabs Hoodline Fenders. This also included the installation of front amber LED turn signal lights.
-Installed GenRight Tall Tub Panel Guards
-Installed Smittybilt Spice Extended Brief Top
-Performed Jurassic Park Jeep Paint Job per EdynB's measurements/angles using Sand Beige Metallic (1992 Jeep Wrangler) and Ford Performance Red (1992 Ford Explorer). This included the use of reducer, hardener, and various miscellaneous supplies. Also used Hare's Den (AKA Decal Nerds) for the number stencils and Decal Hunterz for the JP Logos on the doors, all from Etsy. Prompt and great customer service from both.
-Installed Rugged Ridge LED Light Bar Mounts, along with 52" LED light bar.
Everything on that list took A LOT of prep work. It really helps if you're doing it with a friend so the journey is enjoyable because it's A LOT of work. Four years ago JD and I talked about getting Jeeps and turning them into JP Jeeps. Shortly after we both purchased Jeeps. We finally did it to mine, and I don't think this will be the last one we do...
And remember, other than the hard parts, it's easy.
Re: JP 13 TJ - We Will Rebuild
Wow! This rig looks awesome! I especially like the fact that it is ready to do some decent Rockcrawling! It gives me hope fo my 06 LJ Rubicon "Dino Search And Recovery" theamed project! However I'm thinking of using Olive Drab paint/decals for all the standard red ones.
I don't know if you're familiar with the area, but we've got some pretty decent rock crawling in the Sierra Nevada's up above Fresno. Gotta be equipped!
I also contemplated doing the whole thing OD, but knew I'd always regret not decking it out in full JP regalia. I never thought about doing the stripes/decals OD. That'd probably look pretty cool. I also like that "Tank" green JK color.
VERY COOL!
