JP 12 in Fairbanks Alaska
- sfuflash23
Re: JP 12 in Fairbanks Alaska
Oh, the torx that I was using are craftsman. Thanks for the advice everyone.
- PaulRevere1991
yea, the roll bar stayed in for paint cause of that exact reason.
- sfuflash23
Ok so I need some opinions. This is my first big vehicle project and I dont know a whole helluva lot about suspensions, but on mine the guy had put the suspension over the axle so I shouldn't have to replace any of the leaf springs, but he did torch off the lower shock brackets and he moved them up a bit so that he would have clearance with the lift. My question is that If I get shocks to take me back down to stock height, could I still use the mounts where he has them or would I have to get a new set of lower shock mounts and put them back where they originally were? ( I know what the CORRECT answer is, my question is would I really hurt the jeep by letting them where they are)
Any Advice would help...Thanks in advance y'all.
BTW Shipping is absolutely aweful to come up here. $103 for 4 shocks...Id rather get them sent home to PA for free and have my family ship them up here for like $30-$40...
I kind of feel your pain, even when I used to live in Hawaii, shipping was horrendous.
- PaulRevere1991
your probably better off replacing the shock mounts. and you might want to replace the leaf's, they are 17 years old
- sfuflash23
Hey all, sorry but duty called so I was gone for a few weeks. Back to ripping the jeep apart. Ive got a lot done so im gonna separate the posts so that they follow the individual days I worked on the jeep.
- Broken bolts have been the bain of my existence on this jeep. Most of the bolts came right out with some pb blaster and a quick hit from the torch. others were not so forgiving. Had to drill alot fo them and use the bolt extractor things, and then the ones really in there i had to completely drill out. Just gonna have to put a bolt on the bottom of some of them now since the OEM bolt welded to the body is now to big due to drilling.
- Here is that rear shock mount I told everyone about. Cant believe this, and his weld was awful. What Im gonna try is swap out the front ubolt plates with the rear ones. The front ubolt plates had rods attached that are meant for a shock mount. I measured it out and when I put the leaf springs back under the axle, they will extend out exactly where the old mounts would align, its just they will be about 1" higher. Dont think it will be a large ordeal since I wont be doing any serious off roading with her. If it doesnt work then I will break down and buy shock mounts and weld them on.
- PaulRevere1991
some of those holes where the ammo cans were for the back part of the side steps, looks like you need a new set since they were cut.
- sfuflash23
Already taken care of. Kind of upset at myself though...went to the local junk yard and asked for a set, the guy said he didnt have any...so i ordered a set i luckily found on ebay, except shipping was almost $120!!! I got the damn things for $50. After I had already bought them the weather cleared up up here and I went to the Salvage yard again and asked to just go to the parts jeep to look around for myself, low and behold, 2 feet below the slow lay 2 side steps in perfect condition that they guy said I could have for $70...FML!!! O well, at least I know what at the salvage yard now! Im getting my rims as well as the rear tire carrier, Spare tire stop and bumps, and a new windshield frame from there. One of the salvage jeeps even has an A/C unit in it!! Gonna wait till summer and see if its worth the whole days work to try and yank it out.
Is this bone yard a pick and pull?
- sfuflash23
for some things, but larger things like rims and stuff that they need to lift or move the vehicle for they will do.
